  • 1 Vote(s) - 3 Average
[Engine] "overcooling"
My Berlingo 2009 VIN: VF77J5FS09J333365
I get an engine management faulty light. If I run the engine really warm driving in third for a while from cold start it goes off.
I just changed the thermostat, that  did not work. Also changed the o2 sensors.
I notice that the engine turns on the cooling after 105 as it is supposed to if I can provoke it to even go there.
Usually it will only be about 50 degrees celsius.
On my OBD scanner there are no faults but running the engine the IAT temperature is only 16 degrees, while the ECT temperature is 60 degrees.
Does the vehicle have som kind of coolant bypass valve that might be stuck open?
Something wrong with the management of the electric cooling fan?
Kindly, Adam.
Welcome,
The only thing that comes to mind is that there's a faulty sensor somewhere. Can you get access to someone with Diagbox?
2011 B9 DPF warning light
Last Post: IKUN
Yesterday 09:44 PM
Frequent DPF REGEN's
Yesterday 08:43 PM
Power Steering gone - reservoir full, hoses and ...
Last Post: Collapsedsuspension
Yesterday 02:29 PM
Last Post: paulod
Yesterday 12:05 PM
Power flex anti roll bar bushes
Last Post: NANO_Vigo
Yesterday 10:54 AM
Power flex lower wishbone bushes
Last Post: AD246
Yesterday 08:54 AM
How to change your username
Last Post: Mike
16-01-2025 11:04 PM
Spot the Berlingo(s)
16-01-2025 12:20 AM
knocking from rear
15-01-2025 04:59 PM
Last Post: Andhall
15-01-2025 04:59 PM
