3rd gear crunch
Hello new here. I have an 06 berlingo that crunches going into 3rd every time unless you let the revs come down to idil speed. Any idea what might be causing it? Thank you
Usually caused by worn synchro rings in the gearbox, but sometimes there can be a problem with a shift linkage.
[-] The following 1 user says Thank You to SinsBird for this post:
  • Jameshannaa
When you shift from 2nd to 3rd try giving the revs a blip just before you engage 3rd, it may help.
(04-01-2023, 12:12 AM)Jameshannaa Wrote:  ...
If the problem is in the synchros you can do rev matching and double clutching when shifting. When shifting from second to third, clutch neutral, clutch third. When shifting from fourth to third, clutch neutral, blip the throttle so the rpm goes up, clutch third. You will learn how much to rev when downshifting and how much to wait for the rpm to come down when upshifting as you go.
Or you can get another gearbox fitted instead of learning how to live with it.
On a serious note, try a full gearbox oil change and see if it improves. New thick oil slows the gears down more between gear changes for a smoother shift.
Diagbox 9.91 free download
Last Post: Slowmo
Yesterday 06:29 PM
Last Post: Slowmo
Yesterday 06:26 PM
» Replies: 29
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
Last Post: chrisl
29-01-2026 07:06 PM
28-01-2026 09:18 PM
Cheap(er) oil
28-01-2026 03:39 PM
