Thanks Given: 1
Hi guys I am looking at getting a Berlingo 2015-2018ish it needs to be Petrol as I don't do many miles. I am a keen beach fisherman I also have an inflatable FRIB 330 rib type fishing boat and a 15hp outboard engine. The boat is deflated and packed in the boot to get to launching spots. So I am looking for a car with a large boot and it looking like the Berlingo would be perfect. I am just a little reluctant to get a citroen again as many years ago I had a xsara VTR coupe and had quite a bit of trouble with it.
How reliable are the petrol engines? What year and trim would you guys recommend. I only do about 5k miles a year as I live close to work and can walk cycle. It will be used for fishing / camping trips and weekends away etc and school runs and what not. I quite like the versions with the rear window that opens not sure what spec that is?
How are they to drive? Is there any other type that might be better such as a Tepee ?
Matt
Threads: 2
Thanks Received: 2 in 2 posts
Thanks Given: 5
(04-01-2023, 01:51 PM)Mattallica Wrote: Hi guys I am looking at getting a Berlingo 2015-2018ish it needs to be Petrol as I don't do many miles. I am a keen beach fisherman I also have an inflatable FRIB 330 rib type fishing boat and a 15hp outboard engine. The boat is deflated and packed in the boot to get to launching spots. So I am looking for a car with a large boot and it looking like the Berlingo would be perfect. I am just a little reluctant to get a citroen again as many years ago I had a xsara VTR coupe and had quite a bit of trouble with it.
Matt
Hi Matt, I wouldn’t rule out a diesel because of your low miles. Mine is a 2015 automatic diesel and I only do 5-6k yet I get 45-50 mpg around town, up to 65mph on a long run. Be aware that before April 2017 tax for mine is only £30 annually which is locked in but later models I think cost £175 annually.
2015 Citroen Berlingo Multispace 1.6 e-HDI 90 XTR ETG6 Auto
Threads: 47
Thanks Received: 71 in 65 posts
Thanks Given: 121
7
On the opening rear window question, it was fitted as standard to the XTR model over a couple of years (my 2016 XTR had one) and I believe it was included in some special editions and an added cost option on other models. Having had the opening window I was surprised how infrequently I actually used it. I always thought the coiled cable for the heated rear screen was a bit vulnerable to damage.
Matt
2019 Multispace BlueHDi 100 Flair Nimbus Grey Met
Threads: 63
Thanks Received: 886 in 793 posts
Thanks Given: 145
108
04-01-2023, 10:12 PM
(This post was last modified: 04-01-2023, 10:19 PM by Zion.)
I've never seen a B9 petrol, if they made any, they'll be like rocking horse poop. That wee 1.4 non turbo would surely struggle to pull a big B9.
I've had 3 X 1.6 HDi vans, I only do 10 miles a day to work and never had any bother with the DPF.
It regens eventually regardless of distance when the soot hits the limit. It doesn't just get hot from driving it, the ECU starts a regen by injecting extra fuel and lengthening the injection duration, which heats the DPF to 900° in minutes.
Threads: 63
Thanks Given: 145
108
05-01-2023, 07:10 AM
(This post was last modified: 05-01-2023, 07:12 AM by Zion.)
Ah apologies I thought the 1.2 only started on the K9. It is indeed a B9 but there won't be many for sale compared to the HDi version. Best of luck though with finding the right one.
Never owned a petrol one so can't comment on what they're like. Very rare up here.
The following 1 user says Thank You to Zion for this post:1 user says Thank You to Zion for this post
• Mattallica
Threads: 22
Thanks Received: 21 in 20 posts
Thanks Given: 12
4
I only do about 2K miles a year in my van (1.6 Hdi), I wouldn't worry. Just change the oil every year regardless of milage and give it an Italian tune up every now and then...
My van: 2008 Berlingo 1.6 HDi Enterprise - a bit ratty!
