I have a 2013 WAV that we use as a camper. Removed all the WAV fittings including winch and wheelchair belts etc...
The winch was attached to a steel plate that covers the footwell at the rear. This is bolted in place with the front seat bolts (the back 4) and then about 8 hex bolts where the plate meets the top of the inclined floor that was put in for the wheelchair.
I have had this plate off as the electrics for the winch are under it and I now use this wire for the split charger but the question is, does the plate offer any structural integrity to the vehicle or was it just added for a winch mounting spot and to level the back floor?
Ideally I would like to remove it as it still has the footwell storage spots and it does give a bit of extra headroom if needed.
Any ideas if its safe to take out? I would assume the inclined floor would be equivalent to the original floor in terms of strength so my initial thoughts are it would be fine?
ETA - photo attached. Ignore my daughters collie - she doesn't like cars!
Cheers
Cheers
