Threads: 2
Hi Everyone can someone tell me or better a picture of where the map Sensor is located Please, engine will start on jungle juice and once did tick over for a while but then cut out when touch accelerator.
Thanks Craig
Threads: 75
Thanks Given: 223
164
13-01-2023, 11:25 PM
(This post was last modified: 13-01-2023, 11:28 PM by Sol.)
It's more likely to be the MAF sensor. A HDi will happily rev with no boost, just has no grunt. It will never cut out due to no boost pressure signal. What made you think it was the map sensor?
Sounds like you're getting no fuel (FPR) or have no airflow data going to the engine ECU. (MAF)
Try just unplugging the MAF, it will run on the default fuel map values.
