First fan stops now a warning light
So the resistor for the fan is ordered and delivery is due this week but yesterday there was a beep and the yellow warning triangle appeared.
No other warning lights and engine seems to be running as normal.
Switched off and on and light is off but reappears after a few minutes.
Is this a dealer job?
Think you need some sort of diagnostic for error codes. If it’s driving ok fit the new part and see if there is any change, if not diagnostic is the only way forward that I can think of.
[-] The following 1 user says Thank You to OMG for this post:
  • dickl
As per the handbook, a yellow warning triangle that stays on is an unspecified "major" fault. One that goes off quickly is a minor fault.
Needs a diagnostic. But...see below, and the manual is attached...the fault will be logged in the display screen menu / fault log on-board, read the manual for how to access it (chapter 4). That way you can see the error for yourself before going to the garage. Use the stereo / steering wheel controls / stalk to navigate the fault menu.
Attached Files Thumbnail(s)
.pdf   berlingo_berlingo_berlingo2tp_ed02-15_en_us.pdf (Size: 11.28 MB / Downloads: 26)
  • OMG
Thanks for the manual! Stuff in there I did not know!
  • Sol
(17-01-2023, 06:55 PM)Zion Wrote:  As per the handbook, a yellow warning triangle that stays on is an unspecified "major" fault. One that goes off quickly is a minor fault.
Thanks.
I'm probably being stupid but I can't find any relevant instructions in Chapter 4. Is there a specific page I should look at?
Something I noticed today as I wasn't driving and could look at the "screen" is that it briefly displayed a message "Fault" "Engine" when the light came on.
Ok, so to read the fault log which may not show anything, select "diagnostics" in the trip computer for an indication of the problem.
Also the triangle can come on if the service interval has been exceeded. What mileage does the SI show when the ignition is turned on, in the square display below the fuel and temp gauges?
If none of this is hitting home then you will have to bite the bullet and take it to a garage for diagnostics.
With nothing else to go on, we're not going to solve this in a forum from just a general warning light which could be used for anything at all.
Thanks. Much appreciated.
I've found the diagnostics but the only thing it tells me is that the Child Safety is Inactive then it's complete.
Perhaps I have to try it when it fails.
I've booked it in to the dealers at the end of the month and will report back.
An interesting morning at the dealers.
I arrived early and explained the problem to one of the mechanics.
Unfortunately there was an issue with the loan car and they said if I could wait they'd fit the resistor (I'd taken it with me) and I'd have to come back for the warning light.
Resistor fitted and I arranged another visit.
20 mile drive back home. Fan now working but NO warning light... (it was on all the way over to the dealers)
I think I'll wait and see what happens.
Thanks for the help and advice.
Sounds good, fingers crossed for you that it's resolved.
(30-01-2023, 02:09 PM)Zion Wrote:  Sounds good, fingers crossed for you that it's resolved.
Back again   Huh
20 miles back from the dealer and no light.
10 minutes across town just now and it's back  Sad
Still booked in for the week after next. Let's see what happens then.
Apple Carplay
02-04-2026 01:26 PM
Last Post: Transmit
02-04-2026 11:21 AM
