What is this please?
Can someone tell me wht this is in the picture please by the arrow?   I am hoping it is something I can pull off and will give me access to pass a wire through.
They look like caps to cover the end of a bolt. Probably not a good idea to mess too much with it.
(18-01-2023, 01:06 PM)Gadgetman Wrote:  They look like caps to cover the end of a bolt. Probably not a good idea to mess too much with it.
Yes that is the worry.  I was hoping that I could access the clutch entry point - mine is auto.
Those will be the bolts holding your steering shaft to the floor John. The clutch entry would be much higher up. The clutch on the manual is hydraulic, same height as the brake servo rod from the brake pedal. Same system.
  • John Bilko
(19-01-2023, 07:06 AM)Zion Wrote:  Those will be the bolts holding your steering shaft to the floor John. The clutch entry would be much higher up. The clutch on the manual is hydraulic, same height as the brake servo rod from the brake pedal. Same system.
Thanks Scott.
I'll find a route sooner or later. Big Grin Big Grin
Make life easier - go automatic. Cool
[-] The following 1 user says Thank You to John Bilko for this post:
  • Sol
Where are you actually trying to run a wire to/from and for what purpose??
(19-01-2023, 02:48 PM)Multispacer Wrote:  Where are you actually trying to run a wire to/from and for what purpose??
From the battery to the glove box.
Ah, wish i'd known that yesterday.. think it just threw one away...
2012 Citroen Berlingo M-Sp Air Xtr E-Hdi
there is a cable already from the battery that maybe you can use
check this post about a permanent power connector
https://www.berlingoforum.com/thread-18779.html
[-] The following 1 user says Thank You to jocas74 for this post:
  • John Bilko
(22-01-2023, 04:08 AM)jocas74 Wrote:  there is a cable already from the battery that maybe you can use
Oh wow, that is a great link thanks.
When the weather allows me to get out there I'll try to do it.
I have had the glove box off loads of times dealing with this but I don't recall seeing that plug with the white lead.  Mind you, I was not looking for it!! Rolleyes Rolleyes
Something I found troublesome is that there is a big "thing" plugged into the fuse box which I believe is for the auto gearbox's electricals and it makes accessing the fuses a nightmare.
Yesterday 05:06 PM
Yesterday 04:54 PM
One thing after another
14-11-2026 10:56 AM
14-11-2026 08:44 AM
