  • 18 Vote(s) - 3.11 Average
90-110 bhp differences?
What are the differences between the 90bhp & the 110bhp hdi engines, i imagine fuel pump pressure, injectors & intercooler, anything else? Or would an engine swap be easier?
This is the HDi you are asking after.
To the best of my knowledge, the 110 was never fitted in the Berlingo.
The differences are an intercooler, ECU rather than pressure operated wastegate on the turbo, therefore ECU is different and at least the actuator on the turbo itself. Pump pressure is, I think, the same and I also believe the injectors are the same.
If you are thinking of taking this route I would ask why? Depending on your answer, there may be an easier way of achieving your goal.
I've got the HDi 110 in my Berli. Turbo is different too being a twin scroll variation.
In the UK only the XTR is available with the 110 diesel.
(According to the Cit. website.)
Not worth doing an engine swap IMO (Unless your engines knackered that is!) Adding a FMIC, de-cat with a remap to a 90 would see 150ish bhp IIRC Smile
'04 Peugeot Partner HDi LX. Lows, Leaks and Wellers. Now matt grey and dent free Smile
yeah a remap is the way forward it would take you up to 120bhp it makes a big difference
(16-02-2012, 07:47 AM)3rensho Wrote:  I've got the HDi 110 in my Berli. Turbo is different too being a twin scroll variation.
Beg pardon - I forgot about the Mk3 only thought about the M59 when I saw the question.
If it is purely more power you are after, then, as berlingo power & PeteA say, the better route is as above. It is simpler and can be done in stages should you wish.
(16-02-2012, 06:53 PM)berlingo power Wrote:  yeah a remap is the way forward it would take you up to 120bhp it makes a big difference
This sounds good - presume torque is higher too?
Any supplier recommendations? Cheers.
2003 Multispace 2.0HDi
Yes - where are you?
Do you have Bosch or Siemens ECU?
I'm on the siemens ecu and yes torque is more important than outright bhp, im a plumber so the van gets loaded.I'm based in leicester so wheres the best and nearest place for a remap?
M59 1.4 Petrol question
Last Post: Gadgetman
Today 01:30 PM
Cold Starting
Last Post: jboy012000
Today 10:46 AM
Yesterday 08:12 AM
2015 Berlingo van for sale
Last Post: eddyale
16-03-2025 06:47 PM
Last Post: deejay_xb
16-03-2025 02:53 PM
» Replies: 29
2.0 HDI. engine won't start
16-03-2025 01:48 PM
Unusual Braking Problem
16-03-2025 07:52 AM
valeo alternator CL15 rebuild
16-03-2025 07:49 AM
15-03-2025 06:19 PM
oil Sump
15-03-2025 06:18 PM
