Threads: 2
Hi. when servicing our 2017 Berlingo 1.6 8 valve I noticed that the air filter was vibrating where it fits the rocker cover, where is the best place to get replacement rubber bushes for this? The other thing I was wondering was there is a small pipe connected to the air cleaner on the right side beside the main pipe the turbo, what is the pipe for?
Thanks,
Ronnie.
Threads: 75
Thanks Received: 1,306 in 1,140 posts
Thanks Given: 223
164
21-01-2023, 09:44 AM
(This post was last modified: 21-01-2023, 09:47 AM by Sol.)
The small pipe is the breather for the crank case vapour. If it's damaged or not connected, you get unmetered air entering the engine, which will cause problems. The connection can be brittle and pop off easily on the early B9s.
The filter rubber mounts are best gotten from eBay. It's a common issue.
https://www.ebay.co.uk/itm/363321513622?...media=COPY
Threads: 75
Thanks Given: 223
164
No worries. The link I posted is to the correct parts.
