How do you see the cab fan controls at night?
Hi All,
Bought one of these funky buses yesterday.
Now driving it this evening.. I couldn't see anything to adjust the cab fan/heat! What's going on here? Is it a design fault that they are not illuminated, or has something on mine broken? Model in my signature.
2012 Citroen Berlingo M-Sp Air Xtr E-Hdi
They definitely are illuminated, so it's likely the lamps have blown, or sometimes it can just be a bad connection. Sometimes a 'calibrated tap' of the front panel can make the lamps come back on  Wink
[-] The following 1 user says Thank You to Multispacer for this post:
  • Abaddon
I shall endeavour with some percussive maintenance tomorrow!
(22-01-2023, 12:25 AM)Abaddon Wrote:  I shall endeavour with some percussive maintenance tomorrow!
If that doesn't work also check the connector on the back of the controller is properly seated in. You can get access by removing the stowage just above the heater controls. The stowage literally just pulls out towards you [it will be quite stiff as there is a fitting on the back of the stowage that fits into a rubber bung type assembly]
Attached Files Thumbnail(s)
Try to replace the bulbs. There are two bulbs there, the access to the bulbs from the back of the panel.
Really appreciate this! The circle, ac, and windscreen is illuminated, just not the dials. I assume they are separate bulbs?
Yes there are separate bulbs for the dials...look at the pictures.
Thanks again!
Yesterday 03:29 PM
Last Post: Triggermann
Yesterday 01:47 PM
15-07-2026 12:17 PM
Last Post: wbchevron
15-07-2026 09:32 AM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
Berlingo 2026
11-07-2026 03:17 AM
10-07-2026 02:32 PM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
