Incredible
I suppose this is going to yet another of my Berlingo DIY pet hates. Sad
Changing the air filter is what I am referring to - what a game!! Angry
Not done it yet and don't want to either. Big Grin
I am looking for a K&N filter which is fit it and leave it. Cool
Make life easier - go automatic. Cool
K&N filters are NOT 'fit it and leave it' filters.
No air filters are that.
The closest you can get to that is the old oil-bath systems fitted to old diesels...
(I'm working on restoring an old Nuffield 343 that's been modified to mount an old backhoe system. And yeah, it has the oil bath)
(24-01-2023, 10:29 AM)Gadgetman Wrote:  K&N filters are NOT 'fit it and leave it' filters.
I take your point but I don't do a great deal of miles per year and this is what interests me and I quote
" up to 50,000 miles between air filter cleaning. Not having to buy another air filter means the K&N filter is also environmentally friendly."
 I have had these on all my motors (bar a few) but on this motor the fuss and performance needed to change the filter makes me want to get one all the more. Wink
50,000 would last me about 10 years!
Sent from my CLT-L09 using Tapatalk
2012 Citroen Berlingo M-Sp Air Xtr E-Hdi
K&N filters are a gimmick.
ex: 2003 1.4i cargo
I think you will find that K&N filters need periodic servicing, which involves cleaning and re-proofing with K&N products, which work out quite expensive.
Just stick to the normal filter, it will probably give you upwards of 20K, if not used in very dirty environment.
Geoff
Which engine have you got? All the ones I've ever worked on have been really easy, just open the box at the front of the engine bay.
Maybe I'm just being bitter because I've just changed the filter on my bike, which involves removing the fuel tank  Rolleyes
(29-01-2023, 05:42 PM)ItsGreen Wrote:  Which engine have you got? All the ones I've ever worked on have been really easy, just open the box at the front of the engine bay.
The B9 HDi has the filter to the rear of the engine, under the scuttle shelf. It's not great to access.
Which model has the air filter at the front? Apart from my first van being a 1.9d I have only had HDi engines and can't remember seeing any engine where the filter was at the front.
It's one of those things that makes me think that most owners have the garage work on it.  I am just musing but I wonder how many DiYers own Berlingos - I see many of these motors being converted ones.
My 2.0 8v HDI has it at the front on the gearbox side, think it's the same on the 1.9's, long time since I worked on one though.
Today 01:49 PM
Yesterday 10:07 PM
11-07-2026 12:02 PM
Berlingo 2026
11-07-2026 03:17 AM
10-07-2026 02:32 PM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
