I have a 2006 Citroen Berlingo 2.0HDI Enterprise that needs a new alternator. The original alternator was replaced nine years ago. I'm looking for the OEM part number as searching using my reg brings up a lot of different models.
Cheers,
Martin.
Threads: 8
Thanks Received: 507 in 455 posts
Thanks Given: 306
37
Using your VIN number on
https://www.catcar.info/citroen/?lang=en is your best bet to get the part number.
Look under "Electrical Components"
Thanks for the reply. I have tried what you suggested but for some reason my van is not found..
Threads: 8
Thanks Given: 306
37
Yes, for some reason not all VIN numbers work.
You will have to look for the part manually, just chose your vehicle type, then choose the engine type, electrical components, current generation, find the alternator then you will see the part number.
