25-01-2023, 12:30 PM
(This post was last modified: 25-01-2023, 12:31 PM by AF1.)
Hi
Newbie. I searched but no results for throttle position sensor. EML on. The diags say TPS fault. Firstly is it on the pedal please? Second is it possible to clean it? Third is there an alternative to Citroen Genuine Part?
Berlingo 1.6 HDi 90 (92 hp / 68 kW) 2012
Threads: 75
Thanks Given: 223
164
25-01-2023, 09:23 PM
(This post was last modified: 25-01-2023, 09:25 PM by Sol.)
What's the actual code your getting ? Generic diagnostic tools are notoriously bad on these. Often pulling the wrong code description.
Diesels don't have a throttle plate like a petrol. The pedal is electronic and the engine is revved by the ecu increasing the injection rate.
Threads: 75
Thanks Given: 223
164
26-01-2023, 02:36 PM
(This post was last modified: 26-01-2023, 02:38 PM by Sol.)
Ok, so the actual official definition is as below
P0102 Flowmeter signal : Measured flow less than the minimum flow
So it is likely you have either
1. Fitted an EGR blank plate recently
or
2. The MAF sensor is bad.
or
3. The EGR is jammed open
If you have not fitted an EGR blank plate (which does not work on the B9, it flags the faults above) then try unplugging the MAF sensor when the ignition is off, then start it and see if it drives correctly after the MAF is disconnected, if so, then likely it needs a new MAF sensor.
Also check for splits or gaps in the plastic pipes of the intake after the MAF and between air filter and turbo inlet.
Threads: 75
Thanks Given: 223
164
That's a good video, I love LM Auto Repairs and follow his stuff, also a member of his own forum - recent discovery.
