25-01-2023, 06:57 PM
Hi all. Been having a hell of a time with my dad's DV6B Berlingo and the fuel injector spill rail(fuel return rail). I seemed to have broken it when I was leaning over the engine when I changed his starter motor recently. No biggy got a good quality one (I believe) from autodoc and fitted it, since then I've had to replace the seal twice on the number 3 injector post and now the number 2 post. When I got the replacement the seals were a bit to big makinging impossible to get them in so I reused the old (probably a mistake) with the replacement seals they are from a spill rail that came of a DV6 8v from a mk4 mondeo. Seals are Identical but for some reason are still tearing after a while causing a leak. When I push the posts down they are definently seating correctly as I am able to get the hold down clip in no bother. Am I doing something wrong or is there a trick or something I am unaware of.
Cheers people
Baz
Cheers people
Baz
