09' Multispace to van conversion
Threads: 29
Thanks Received: 38 in 33 posts
Thanks Given: 146
11
27-01-2023, 07:41 PM
(This post was last modified: 28-01-2023, 03:49 PM by jemselectrical.)
Hi,
I'm in the process of converting my newly acquired petrol Multispace into a work van to subvert Kahn's ULEZ.
One particular issue I am encountering is the front seat chassis mounts that are in the rails of the chassis. The outer pairs are contained in a spot welded square cage within the rails and are not movable. All of the rest of them are a GRP modular unit that must've been installed after the chassis was painted and appear to be a slide in unit that passes through the rail and supports an approximately 30mm wide by 6mm thick M10 square nut on the top of it, which the seat bolts engage with. The nut is able to freely move upwards to clamp against the underside of the chassis rail
The modules are able to be installed to suit the multiple different seating setups: LHD with single passenger seat, RHD with single passenger seat, LHD with dual passenger seat and RHD with dual passenger seat
The issue I've got is how in the hell do I get the damn things out?
I'm changing from two front seats to the split dual passenger unit from the van version. I need to move one existing one, and add three extra ones in.
Pictures to follow:
any info will be greatly appreciated, cheers James
Threads: 29
Thanks Given: 146
11
Threads: 29
Thanks Given: 146
11
Threads: 29
Thanks Given: 146
11
P.S: To do any of this you will need to completely take out the floor carpet unit in the mid/rear footwell to access the rearward front seat rails, and raise up the front footwell section to access the forward front seat rails.
Threads: 75
Thanks Given: 223
164
28-01-2023, 09:27 AM
(This post was last modified: 28-01-2023, 09:28 AM by Sol.)
Excellent bit of work James, I'm going to sticky this thread as there are always people looking for info on seat issues / camper conversion etc.
• jemselectrical
Threads: 29
Thanks Given: 146
11
Threads: 123
Thanks Given: 250
34
I've not driven down to 'The Smoke' in quite a few years so am a bit puzzled about ULEZ and how it applies to diesel Vans vs Cars. Don't they both have to be Euro 6 compliant?
For the load bed extension, you may get an advisory on your MoT if the rear seats are missing?
Threads: 2
Thanks Given: 2
This is really useful - I have often thought of changing my camper front seats to the van configuration so I have 3 up front. Be really interested to see the finished job!
With regards to MOT advisories - I have had none with all rear seats missing in the last 2 years so I don't think they check?
Threads: 123
Thanks Given: 250
34
(31-01-2023, 11:13 AM)dxcamper Wrote: With regards to MOT advisories - I have had none with all rear seats missing in the last 2 years so I don't think they check?
I think it depends on the MoT testing station or individual tester. If there are no rear seats, they can't test the seatbelts and may / should note that on the MoT Test Cert.
Threads: 29
Thanks Given: 146
11
31-01-2023, 12:23 PM
(This post was last modified: 31-01-2023, 12:25 PM by jemselectrical.)
(31-01-2023, 11:30 AM)cancunia Wrote: (31-01-2023, 11:13 AM)dxcamper Wrote: With regards to MOT advisories - I have had none with all rear seats missing in the last 2 years so I don't think they check?
In terms of legality and MOT compliance, if the factory seats are removable, and not in situ when MOT'd, then they are simply omitted from inspection and noted that they were absent so could not be tested.
However, the V5C clearly states how many seats are declared at registration, so by changing the front seating arrangement to three seats one of the rear seats has to be omitted unless you then apply to change the V5C to incorporate extra seats, which then opens up the can of worms that is vehicle insurance declaration and dumps you in the "modified vehicle" nightmare. The V5C does not specify where the seats are in the vehicle, only how many. That's something you do need to consider with something like this.
Taking seats out does not affect insurance, only addition above the original amount at registration.
06-10-2026 04:12 PM
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
removing front strut
16-09-2026 02:07 AM
