  • 14 Vote(s) - 3.14 Average
No heat and overheating
Hi. I have a 1997 1.9 diesel berlingo. What would cause the heater to stop blowing hot and the temperature light to come on. Checked coolant and that's fine.
Thanks.
(16-02-2012, 12:35 PM)ryanlee Wrote:  Hi. I have a 1997 1.9 diesel berlingo. What would cause the heater to stop blowing hot and the temperature light to come on. Checked coolant and that's fine.
Thanks.
Hi, what is your temp guage showing?
Did you actually take off the filler cap of the reservoir and see if there is any coolant inside?Confusedcratch:
Dead water pump?? No water circulating thru heater matrix - less/no heat. Engine would get hot. Or thermostat stuck closed? Just guessing
Hi, thanks for replies. Checked coolant in reservoir and it's fine. The 2 hoses at back of engine are warm at best. Undone the bleed on these and there was coolant there. The big hose that goes to top of rad is really hot and I get heat in the rad. Temp gage gets just into the red area but not all the time.
Phoned a garage and they straight away said head gasket.
(17-02-2012, 08:57 AM)ryanlee Wrote:  Phoned a garage and they straight away said head gasket.
Unlikely to be the head gasket if it isn't using water.
Cool pipes here, hot pipes there, either a blockage or the stat.
At a guess Tongue
I'd go for a faulty thermostat too. Cheap to test - remove it and see if the problem disappears.
Sent from my GT-I5700 using Tapatalk
One thing after another
Yesterday 10:56 AM
Yesterday 08:44 AM
12-11-2026 10:15 AM
Last Post: Dyane6
02-11-2026 11:10 PM
