Hi got a 2020 Berlingo van diesel any ideas where i can get a permanent 12v live feed for a dash cam apart from going all the way back to battery
(03-02-2023, 07:11 PM)Oi69 Wrote:  Hi got a 2020 Berlingo van diesel any ideas where i can get a permanent 12v live feed for a dash cam apart from going all the way back to battery
Piggy back something in the fuse board, perhaps hazard light?
2022 LWB 1.2 petrol auto combo life (AKA Berlingo K9)
I used a fuse splitter using the fuse position for the 12v socket.
Piggy backed a low rating fuse for the dash cam feed off this.
I'm not sure this is permanently live though and goes on or off with ignition.
2019 Citroen Berlingo 1000 Enterprise M 1.6 BHDi SS
2014 Volvo XC90 2.4
2013 VW Polo 1.6 HDi
Nothing in the cabin is permanently live except the hazards. But then you don't want your dash cam on constantly so I'd do as above. Piggy back hardwire cable from Halfords or Amazon and run it off the 12v socket fuse on the BSI.
I run my dashcam off the USB socket in the corner of the centre screen, which works fine.
2022 E Berlingo Feel M, in Cumulus Grey, with reversing camera
If you mount your dashcam at the centr top of the windscreen you should be able to find a permanent live behind the interior light. I use an ignition live from there so that I dont flatten the battery if it is stood for a long time
Peter
(04-02-2023, 01:15 PM)Romahomepete Wrote:  If you mount your dashcam at the centr top of the windscreen you should be able to find a permanent live behind the interior light.  I use an ignition live from there so that I dont flatten the battery if it is stood for a long time
Peter
interior lights go off after while and wont come back on unless door opened or ignition switched on
(04-02-2023, 09:30 AM)Zion Wrote:  Nothing in the cabin is permanently live except the hazards. But then you don't want your dash cam on constantly so I'd do as above. Piggy back hardwire cable from Halfords or Amazon and run it off the 12v socket fuse on the BSI.
i do want it on constantly it has voltage drop sensor so wont flatten battery just switch its self off
Peter
Correct. I have my rear cam monitor (mirror monitor) connected across the map light pins, but had to remove the bulb or it stayed on constantly. Mind you it works fine as I don't want the monitor on constantly. Only with ignition, which works fine.
You need to check all the wires behind the light
Peter
wipers
Last Post: mickrochip
Today 11:26 AM
Last Post: xavier988
Today 10:23 AM
Today 10:21 AM
knocking from rear
Today 10:19 AM
footwell fan
Last Post: de62
Yesterday 10:13 PM
rear washer fires front?
Last Post: Brooky325
Yesterday 10:00 PM
Remote key fob window function?
Yesterday 05:58 PM
Halp, me van had died :(
Last Post: ae3
Yesterday 05:43 PM
Drop in fuel economy
Yesterday 09:38 AM
Berlingo in disguise..
Last Post: BlackPartner
11-01-2025 09:47 AM
» Replies: 34
