separate dab aerial needed ?
2009 tepee partner
I have searched this but cant find a clear answer
does an aerial adapter splitter to the original roof aerial pick up dab ok or do i need to fit a separate dab aerial
if so does it need to be a powered splitter or a basic one ?
thanks
I have a separate aerial for DAB. Standard ones don't work as far as I know, so that shouldn't work. Just like you have to have a different TV aerial for Digital TV from the previous analogue ones (FM is analogue) - powered or not depends on the head unit requirements or how close to a DAB transmitter you tend to be. Mine is not powered and only picks up local DAB.
cheers for the reply
I half thought as much, as you say it probably all depends on how good the dab signal is in my area but I have no idea.
To save the hassle I will just go for another aerial.
There seems to be many types of Dab aerials available, anyone a recommendation for a specific window mounted one ?
I got one with a Kenwood dab set and it's a stick on windscreen bar type affair but it's not superb if you get me. National stations drop out a lot. I'd love to recommend one but have no suggestions to offer. I'd try Amazon as you can check the reviews.
Strut Top Mounts
Today 07:58 PM
Yesterday 09:30 PM
Yesterday 09:27 PM
Rear seat belt breakage
Yesterday 04:13 PM
removing front strut
13-09-2026 06:10 PM
12-09-2026 05:49 AM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
29-08-2026 08:39 PM
