No heater
Hi all have just bought a 2002 1.9 diesel Berlingo, I’ve no heater in the van I’ve checked the two pipes going through the bulk head one gets warm the other is cold and no change when van is warm? I’ve flushed the rad etc but still no good temp hand seems to sit where it should although if gunning the van this rises? Any ideas what to check or do to repair?
Many thanks
The valve connected to the hot-cold control is probably stuck shut or the steel cable has snapped.
Hi thanks for the reply where is this located is it easy to check? Thanks
Follow the bulkhead heating hoses to the engine and look for a valve operated by a belden cable like a bike brake. When you go from cold to hot at the heating controls, you're just opening a mechanical valve.
It could be inside the dash on the M49 though, not had one of those..but it will be an old school simple lever valve job
When I disconnected the heater matrix on my M49 last year, I can't recall seeing any valves on the hoses, so it might be inside the dash.  (I would just pop out and have a look to confirm, though I've just taken the vehicle to a local garage for its MOT, so any inspection will have to wait until I get it back).
It could be mounted on the heater matrix unit where the hose goes in at one side.
As far as I know the heater matrix is always in play, there is no valve to stop the water supply to it.
I would say the heater matrix is either blocked or has an air lock.
What controls the temperature then JJ, what's on the end of the belden cable?
The heater temperature control dial moves a flap via the bowden cable that lets the air pass through the matrix, if the dial is on cold the matrix is closed off so no heat from it enters the air flow.
(10-02-2023, 12:06 AM)jj9 Wrote:  . . . I would say the heater matrix is either blocked or has an air lock.
Just another thought . .  check along the length of the cold pipe that goes to the bulkhead, could be it has been blanked off somehow if the heater matrix has had a leak.
Ah ok thanks. That's different to the later system. And sorry. Bowden cable.
M59 1.4 Petrol question
Today 06:12 PM
Cold Starting
Last Post: jboy012000
Yesterday 10:46 AM
17-03-2025 08:12 AM
2015 Berlingo van for sale
Last Post: eddyale
16-03-2025 06:47 PM
Last Post: deejay_xb
16-03-2025 02:53 PM
» Replies: 29
2.0 HDI. engine won't start
16-03-2025 01:48 PM
Unusual Braking Problem
16-03-2025 07:52 AM
valeo alternator CL15 rebuild
16-03-2025 07:49 AM
15-03-2025 06:19 PM
oil Sump
15-03-2025 06:18 PM
