Threads: 75
Thanks Given: 223
164
10-02-2023, 12:29 PM
(This post was last modified: 10-02-2023, 12:37 PM by Sol.)
To repeat here for your own thread John, the thing bolted into the steel frame is your engine ECU which is mounted using shear bolts to stop people taking them out. It needs slots cut with a dremel in the bolt heads and a big flat blade driver used to unscrew them. Then the ECU can be lifted out. Do not unplug it however with the battery connected, or it will become "locked" and you will no longer be able to start the car, even with it refitted.
This is a Security feature, which will require Citroen to get you out of, or a trained amatuer with Diagbox. Can't remember your build year. If 2016> then it's pretty much Citroen only on that one. You would also need your 4 character security "pin" code from when the car was new, or buy a copy from Citroen for £45. Then you still have to pay to unlock the ECU.
You would be better to disconnect the battery and all of the plugs. Probably much easier.
The thing I referred to which is often rivetted is the actual top fuse tray, though often not done at the factory any more.
• jemselectrical
Threads: 75
Thanks Given: 223
164
I like the bike - very cool.
Threads: 75
Thanks Given: 223
164
They probably use eazy-outs after drilling a hole in the top. I expect they are to keep MEDDLERS out haha ;0)
Threads: 75
Thanks Given: 223
164
I saw a video of someone I know putting the slots in the bolt heads with a dremel, using a Flexi extension of course, and it wasn't that hard...if you want I can dig it out.
