Threads: 16
Thanks Received: 4 in 4 posts
Has anyone fitted the spare wheel carrier? If so, I'm assuming you need to jack the back end up ? If so how much? Would car ramps be sufficient? Thanks...
Threads: 29
Thanks Given: 67
20
Have you got the hook that holds the carrier up when the wheel is fitted ? You unscrew it with the wheel brace in the back of the boot space.
Threads: 39
Thanks Given: 1
4
We have the Vauxhall Combo life version registered 2021. I bought a sparewheel carrier from a scrap B9 and modified it to fit (It came with the hook and bolt. I had the jack etc from a previous Berlingo. I also bought a full sized spare wheel, I was fortunate in getting one from an almost brand new van that had been written off after a front end smash. The wheel and tyre were only weeks old and so the tyre matches the ones on our car.
Peter
Threads: 39
Thanks Given: 1
4
Mine came from a car breakers and you can fit the carrier when it is on ramps. I was fortunate that it was brand new. I dont know if a full sized wheel fits in the Citroen K9 carrier but it fits in my modified B9 carrier
Peter
Threads: 19
Thanks Received: 31 in 30 posts
Thanks Given: 12
16
I bought a K9 carrier and fitted it and a full sized spare wheel fits.
Blakey, are you not "on the buses" any more then? (I presume you get the reference?)
The link following is for a thread I started some time ago regarding my K9 that didn't have a spare wheel. Post 35(?) from Romahomepete shows a good photo of where to fit a carrier but I suggest you go through the thread anyway and see if that helps -
https://www.berlingoforum.com/thread-19928.html
Now a 2019 K9 1.2 petrol.
