Threads: 2
Thanks Given: 1
Hi
I have a warning saying the rear doors are open even when they are locked and secure.
I have tried the lock at the back and the rear door loom.
I believe the problem is in the connector that links the rear door loom to the main loom the connector is behind the left hand rear light. Does anyone have a wiring diagram for the connector ?
Threads: 75
Thanks Received: 1,310 in 1,140 posts
Thanks Given: 223
164
12-02-2023, 08:58 PM
(This post was last modified: 12-02-2023, 09:05 PM by Sol.)
If it thinks the doors are open, they should not lock. This makes no sense. The entire vehicle would refuse to lock.
The door lock signals are sent by the locks themselves, to the BSI computer.
Get a Haynes manual, the diagrams are not too bad for regular use. I'll see what I can find tomorrow at work, but its way more complex than you probably think.
What year and model do you have, some info would help. Van, car, 2008, 2018, etc. They are not all the same.
Threads: 75
Thanks Given: 223
164
19-02-2023, 09:54 AM
(This post was last modified: 19-02-2023, 09:56 AM by Sol.)
Here is the schematic
Key to items:
Citroen Components.PDF (Size: 153.2 KB / Downloads: 5)
