Possible gearbox problem 2017 1.6 hdi manual
Hi everyone ,
Hopefully someone can give some info. I had a coolant pump fail a few days ago,
I stopped as the warning came up on the screen , stop engine overheat.
I checked top and bottom of radiator and it was only hot on top.
I gave it 10 mins and put the internal heater on full and drove off ( no heat from Internal heater)
Ended up on a tow truck and got a mechanic to change the coolant pump.
I tired to get it into second gear and it felt stuck, Then no reverse ,
I managed to get home using 1st , 3rd and 5th.
Brought to another mechanic the next day , On initial test he could find nothing wrong
All gears worked fine. He took it for a little spin and then the problem came back.
Various gears hard to get it into gear , some impossible and intermittently sticking in gear.
He has checked the linkage and all seems fine , Any light on this really appreciated
with engine stopped can you engage easily all gears?
If you like gaming visit GameForest
(14-02-2023, 10:10 AM)deejay_xb Wrote:  with engine stopped can you engage easily all gears?
Yes with engine off the lever appears to go into gear , i didnt try push the car as i did it
if it goes easy without engine on then you need to replace clutch/bearing and maybe slave cylinder because it does not disengage properly
(15-02-2023, 02:51 PM)deejay_xb Wrote:  if it goes easy without engine on then you need to replace clutch/bearing and maybe slave cylinder because it does not disengage properly
Just an update . Mechanics changed the oil in the gearbox and all is back working
Very weird , I did not expect this to happen , but 1000 km later and no issues
Just to update this . The mechanic took the side off the gearbox .
Emptied out the oil and removed a bit of gunk as he called it
Worked fine ever since
Last Post: Matt Haigh
Today 11:45 AM
One thing after another
Yesterday 10:56 AM
Yesterday 08:44 AM
12-11-2026 10:15 AM
