Side sliding door child locks.
Is there any way for the side sliding doors on a 59 plate Citroen Nemo Multispace to have working childs locks.
I have looked to see about the convential way of manually turning the child locks on but there is no facility to enable me to do this, see photo of sliding door open.
I have read somewhere it is possible to turn a child lock switch to the on position, situated near the menu set of switches but again mine does not have this option, see photo of switches.
Would appreciate some help and advice please Wink
Is the manual child lock not on the rear edge of the sliding door. Your pic shows the front edge.
[-] The following 1 user says Thank You to Pedronicus for this post:
  • Sierra Charlie
It should tell you in the vehicle user manual.
Geoff
(18-02-2023, 05:57 PM)Pedronicus Wrote:  Is the manual child lock not on the rear edge of the sliding door. Your pic shows the front edge.
Many thanks for your reply. Yes you are absolutely correct, have checked and the manual child lock is there Wink
It was situated on the opposite side of the door, conventionally the manual child lock is situated on the same side of the door as the outside door handle. This is the first time I have had a vehicle with sliding side doors. Lesson learnt.
(18-02-2023, 06:24 PM)Guanock Wrote:  It should tell you in the vehicle user manual.
Geoff
Thanks Geoff but unfortunately I do not possess a user manual hence why I placed my original query.
full manual available on web. \search 'Infotec'
Geoff
Yesterday 08:36 AM
» Replies: 15
Last Post: Dyane6
02-11-2026 11:10 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
