Threads: 2
Hello,
I'm in York and am looking for someone reliable to fit a tow bar on a 2014 XTR. Happy to travel a bit if required.
Cheers, Jon.
Threads: 75
Thanks Given: 223
164
17-02-2023, 11:25 PM
(This post was last modified: 17-02-2023, 11:26 PM by Sol.)
You need the towing ECU fitted and coded too. Known as the BSR relay. Can't just hook up a trailer socket to the rear lights as you can on other cars. It blows the BSI outputs, and then you're in big trouble.
Threads: 75
Thanks Given: 223
164
18-02-2023, 07:57 AM
(This post was last modified: 18-02-2023, 08:03 AM by Sol.)
On a 2014, you could use the eBay version of DiagBox to code it, or use Citroen or an independent PSA garage. If it were 2016 or later then it's Citroen only or approved service outlet.
Citroen themselves wouldn't likely code something you had fitted elsewhere so it's either an independent or a talented Diagbox owner.
You have to find the BSR module and fit that behind the passenger rear trim, then the towbar electrics can be wired to that. It's just to point out you can't connect anything to the tail light circuits directly, there are huge red labels attached warning against it.
The reason is, the BSI powers them directly, and nothing over 10ma can be connected without blowing those circuits. Once damaged, you're in a nightmare situation to resolve it. The BSI is hard coded to your vehicle, you can't fit a used one easily, it contains the immobiliser and unique PIN code, so damaging it is a very troublesome exercise.
There could be towbar places around who are aware and have the necessary kit, but beware anyone who says "nah that doesn't matter" because yes, it does.
Threads: 39
Thanks Given: 1
4
If you take it to a dealer they are likely to farm it out to a towbar specialist so you might as well cut out the middleman.
The independents are used to modern car electrics and you can probably get a mobile to come and do it at your house.
Peter
Threads: 39
Thanks Given: 1
4
A few years ago when I had a towbar fitted to a brand new B9 Berlingo I did a deal with the local Citroen dealer who I had a good working relationship with,
I fitted the towbar and remove the trim panel in the boot and they fitted the Citrown wiring kit and configured the electronics thus keeping the warranty
Peter
Threads: 11
Thanks Received: 31 in 31 posts
Thanks Given: 3
7
I fitted a bar to my 2018 XTR, then sent out emails to local tow bar specialists asking for quotes to supply, fit and code the electrics. The company in Huntingdon did a great job at a reasonable price and everything works as it should.
Geoff
