[Warning Light] Eco mode disabled
ECO MODE PROBLEMS
ANY IDEAS.
ECO MODE DISABLED MESSAGE DISPLAYED AND SMALL ORANGE TRIANGLE
IF LEFT UNLOCKED BEFORE STARTING
IV CHANGED THE BATTERY AND HAD THE BSI TESTED
it's normal, if engine is not running after some minutes (20-30mins) the car puts some electronics in eco mode, to prevent battery draining
If you like gaming visit GameForest
(19-02-2023, 12:53 PM)OThanks for the reply. That orange triangle comes on straight away is that normal. ?car drives fine deejay_xb Wrote:  it's normal, if engine is not running after some minutes (20-30mins) the car puts some electronics in eco mode, to prevent battery draining
check also battery voltage before starting the engine, if it's below 12.2 charge it or if it's old replace with a new battery
(19-02-2023, 02:44 PM)HI iv replaced the battery with a new one. Still the same. deejay_xb Wrote:  check also battery voltage before starting the engine, if it's below 12.2 charge it or if it's old replace with a new battery
post a pic with that orange triangle
(19-02-2023, 03:24 PM)deejay_xb Wrote:  post a pic with that orange triangle
Attached Files Thumbnail(s)
i don't think that triangle is related to the eco mode message
scan the car for errors using diagbox and post here all errors detected
maybe it's time to service the car, change oil, and reset service counter
https://www.youtube.com/watch?v=gmRmvi7XFao
That's the fault led, could be anything from a simple issue to an engine fault. Multiplexed additive pump fail for example. I had the triangle when my DPF additive pump failed.
It's in the manual. You will have to scan it with Diagbox. Don't bother with anything generic, it won't find the correct codes.
08-10-2026 07:24 PM
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
removing front strut
16-09-2026 02:07 AM
