Noise and vibration above 40mph. Stops with braking and right turn.
Hi all.
I have a 2014 XTR which we have owned since it was 6 months old (5k miles). Now it has 92k on the clock. Regularly maintained and well looked after.
It's been trouble free until recently.
It had is scheduled service and then a week later the FAP liquid depleted so went back in for that and I urged for new timing and auxiliary belt (I am over cautious with timing belts and get them done at the first opportunity).
Since this visit we have had a vibration which you can feel (but it's slight) and an awful vibration/droning noise above 40mph. Weirdly it goes when turning right or braking.
The garage tried to fix it with new discs and pads as they where getting about 20k from needing to be changed...nope. came back after 30 miles.
It makes me wonder why the action of replacing the discs or the car being in the air stopped it for those few miles?
Could it be a dodgy tyre? Wheel bearing? (It sounds right but we have had no signs a bearing was letting go) some other bushing?
Any experience or help would be great at its set us back quite a tidy sum this month and I am loathed to finance a front end replacement at this time, ?
Sounds like top strut bearings, they rumble when on the way out,
Also when vehicles been on the ramp or jacked up they make the same noise for a while after
Turning the wheel side to side may make it happen also
Should disappear unless they need replacing.
Drive A Berlingo/Partner 1.6hdi 14-Plate Undecided
If the mechanic moved the steering wheel with engine off then the steering angle sensor gets wrong values. Just drive the car like this for 10-20km or with engine on and car stopped turn left right lock to lock 10 times so the sensor will auto adjust
If you like gaming visit GameForest
Its not something like the engine undertray being loose and vibrating in the airstream.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
I would think this is a wheel bearing problem
2015 Citroen Berlingo Multispace 1.6 e-HDI 90 XTR ETG6 Auto
(27-02-2023, 12:33 PM)artspeck Wrote:  I would think this is a wheel bearing problem
Same thinking here, wheel bearing on the passenger side, hence it goes quiet when you turn right, putting pressure on it.
  • Ian Huitson
Check your wheel nuts.
Now a 2019 K9 1.2 petrol.
Coolant
Last Post: tomhick024
Today 06:18 PM
SOLVED: P20F6 fault
Today 08:28 AM
Leaking windscreen or aerial
15-04-2026 08:50 PM
