  • 15 Vote(s) - 3.13 Average
Water temperature sensor
Hi newbe needs a bit of help. can someone tell how to take the wireing plug off and change a (green) water temperature sensor on a 2003 19d, as i think it is playing up, gauge keeps going up and down, thanks
There is a wire clip that holds is on, prise it down with a screwdriver, remove sensor, remebering to cover the hole or you'll lose the coolant.
I got the electrical plug of by wiggling it and swearing a lot.
[-] The following 1 user says Thank You to steve valentine for this post:
  • miapia221
Hi Steve, thanks for the info, it is working ok now, all i did was just wiggle the plug about, so might have been a loose wire, also when i checked the header tank the cap was just about off so that might have had something to do with it, thanks chris
Can you just push that c-clip down out of the way with a small screwdriver?
Berlingo undertray
Today 04:46 PM
Today 08:32 AM
Today 08:16 AM
03-03-2026 06:17 PM
03-03-2026 05:08 PM
03-03-2026 07:57 AM
02-03-2026 02:51 PM
02-03-2026 02:14 PM
Amdro boot jump for sale
Last Post: YTC1
28-02-2026 09:48 PM
Last Post: Muppets on Mars
27-02-2026 01:57 PM
