Code reader recommendation
Morning - don't really want to spend much more than c. £50 - what code readers would the group suggest? 1.6 Diesel.
Hmm - for a quick to use thing, you can get a VGate iCar Bluetooth adaptor OR the Carista adaptor (both under £20) and then use either the Torque Pro app on Android OR the app called "Car Scanner Pro" on Android. There are no cheap hand-held ones which work on Citroen. The only hand held I had which worked was a Foxwell NT530 or NT560 which is well over £100 and only work up to 2013 vehicles.
What year is your vehicle?
If you want to use the mobile apps and have an Apple phone (the work of Satan) then you are out of luck as far as I know, no apps exist, but could be wrong if any have recently been developed.
The reason most cheap handheld ones do not work is Citroen do not use the standard OBD pins for diagnostics, but have dedicated DIAG-CAN pins in addition to the regular CAN pins, so they adhere to the "standard" but ordinary off the shelf hand-held devices assume only the standard pins will be used. Devices which know to use the proprietary DIAG-CAN pins will be able to communicate. From the ordinary CAN pins, you can only get Emission readiness data and some basic stuff, which is how Citroen comply with the standard without letting everyone read their fault data.
  • eternaloptimist
Well, that's not what I was hoping to read! It's an M59 Multispace, registered early 2008.
I'm an Apple user. I think of Android in the way you think of Apple. Don't particularly want to use a mobile app, but from what you say, there aren't any.
Apologies for this looong post:
Ok so having checked, there are a few Apple apps out now, Car-Check (?) and Torque seem to be available, I seem to remember though that Apple had to use WiFi to connect rather than Bluetooth so you may have to find the WiFi version of the VGate iCar adaptor, there is one out there I'm sure. This info was based on other car makes like Audi, but if you get a WiFi adaptor and an Apple app like Torque which works, you could use that.
How good the apps are, is anyone's guess as I haven't used Apple ones before. Worth a hunt on the iStore or what ever they call it.
You can check out the Foxwell NT range of handhelds (https://www.gendan.co.uk/category_150.html) - the NT530 comes with one car make for free (pick PSA as it contains Citroen too) but you can add other makes if your missus has a different car from you, paying about £50 per additional car brand. Limited to PSA up to 2013 models.
Or if you can find one on eBay or elsewhere, there was a software and dongle called PSA-COM but I have yet to try that, the original gets great reviews but is in the £400 range, so the eBay version, is in the £50 range but haven't tried that personally, it could be great, could be rubbish.
The big issue is Citroen (and Peugeot) use a proprietary CAN and VAN bus system, for which the BSI is the gatekeeper and general network bridge, so traversing the networks (there are 5) requires vendors to know the exact CAN frame IDs to do all of the requests you would need, so this limits general purpose OBD stuff to raw engine codes and even then, not the entire list. Where PSA used the generic PIDS as per the OBDII standard, then these work to an extent but a lot of OBDII PIDS are manufacturer specific and not published, so it's hard for companies to come up with diagnostic software which works properly.
If you want to get the full low-down and have access to a laptop, then you can buy a DiagBox kit for about £80-£100 ish off eBay and then get the software in VM format, to run on VMWare Player, which requires no installation or fiddling and that is very good, but needs experience to use effectively, again not really for the faint hearted. (DiagBox is the official software and the one which comes with the kit is a pig to install, but you need the Lexia-3 interface it comes with, then you buy the software again on it's own but in VM format so you can just run it on a program called VMWare Player, as above - that version of the program costs about a tenner as it does not include the interface)
  • eternaloptimist
Thanks, that's helpful. I'll read and digest.
eolys
Last Post: magoo1
Yesterday 03:02 PM
Rattling calipers
18-05-2026 05:36 PM
Yet another ABS fault
13-05-2026 05:57 PM
Mileage
Last Post: Taffy747
11-05-2026 11:51 AM
11-05-2026 09:17 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
