Outer cv boot replacement
Hi all. As in the title, I need to replace the outer cv boot driver’s side and looking for some advice. I’ve done these before on vw’s and it’s just a case of knocking off the outer cv joint and changing the boot as the inner joint is bolted to the transmission but looking at the Haynes manual for the Berlingo, it talks about draining the transmission oil and removing the whole driveshaft. I’ve not had a look at my Berlingo yet but is this really necessary? Is it possible to just change the boot in situ? Thanks
The drive shaft is splined into the g/box, so to knock off the CV joint the shaft has to be held solid. I've tried it before and found its very hard to get the joint off without the shaft coming out of the g/box and losing oil. No big deal really as the filler plug is very handy to get at.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
  • Hawaii04
The drivers side (RHS) driveshaft isn't that bad as it has the centre bearing so that holds it in place and stops it coming out of the gearbox, the passenger side (LHS) slides out of the box for fun !
The CV joint can be very difficult to remove and the wire C clip that secures the joint is often deformed when you remove the joint so you may need a replacement.
If you can get away without removing the joint I would fit a stretch boot and save a bit of hassle.
I've used the stretch boots & cone from this seller before, they work well and are a good quality product.
https://www.ebay.co.uk/itm/144113297162?...Swh1Vg7w6L
  • Hawaii04
(27-02-2023, 08:40 PM)jj9 Wrote:  The drivers side (RHS) driveshaft isn't that bad as it has the centre bearing so that holds it in place and stops it coming out of the gearbox, the passenger side (LHS) slides out of the box for fun !
great. I’ll give this a try. Thank you for the advice
Can you still get split boots? Fitted one years ago to an Austin 1800 IIRC.
My van: 2008 Berlingo 1.6 HDi Enterprise - a bit ratty!
Yes the split glue together boots are still around but the stretch boots seem to have taken over from them.
For anyone interested. I did this task today and although I originally planned to use the cone method with a stretchy boot, I quickly realised that it would be a complete mare trying to stretch the narrow end of the boot over the cv joint. So instead I used the cv puller tool (£10 off eBay) and disconnected the outer joint. Having put the new boot on, I then tied a large zip tie over the clip on the driveshaft. This helped compress the clip and made reinstallation of the outer joint straightforward. I then cut the zip tie off and tapped the joint fully on.
2008 B9 1.6 HDI 90 BHP Model.  120k
[-] The following 2 users say Thank You to flanagaj for this post:
  • jj9, RJBingham
X2 on using the £10 fleabay CV pullers.
227,00 miles,  (Resurrected at 186,000)
Berlingo undertray
Today 07:56 AM
» Replies: 16
Today 07:07 AM
Yesterday 08:32 AM
Yesterday 08:16 AM
03-03-2026 06:17 PM
03-03-2026 05:08 PM
03-03-2026 07:57 AM
02-03-2026 02:51 PM
02-03-2026 02:14 PM
Amdro boot jump for sale
Last Post: YTC1
28-02-2026 09:48 PM
