Poor performance 2.0HDI
My Berlingo 2.0 HDI was down on performance, sluggish and slow pulling away, it also had the same issue that my last 2.0 HDI Peugeot Partner had, it would not sit at 30mph in 4th gear or 40mph in 4th etc. It would chug/Labour and the only way to stop it was to change down a gear.
In an attempt to address the sluggish performance I bought a MAF sensor off eBay. The transformation was incredible and it now feels like it’s been chipped. It tears away from a standing start and flies along like a new van. The new MAF sensor also cured the chugging issue and it happily sits in 4th at 30mph etc etc without issue. The best £30 I’ve spent for a long while  Smile
I do have another issue that someone can hopefully shed some light on. My N/S brake shoes are being scored by the edge of the drum. I’ve checked for the obvious wheel bearing wear but can’t detect any and everything else seems fine. The scoring only happens whilst cornering a right hand bend or roundabout. Any ideas please?
[-] The following 1 user says Thank You to Van Rouge for this post:
  • Blackshuck
My '04 2.0 HDI is also having the same issues as yours , re labouring at 30 mph in 4th - can you remember the eBay seller you got your MAF sensor from ?
(03-03-2023, 07:17 PM)Blackshuck Wrote:  My '04 2.0 HDI is also having the same issues as yours , re labouring at 30 mph in 4th - can you remember the eBay seller you got your MAF sensor from ?
Hi, the seller was rtgroup11
Attached Files Thumbnail(s)
[-] The following 2 users say Thank You to Van Rouge for this post:
  • Blackshuck, td5
Thanks for that
Mine did this a few years ago, you can diagnose it by just disconnecting the MAF sensor and the car will drive better straight away without putting any warning lights up.
[-] The following 2 users say Thank You to ffrenchie for this post:
  • Blackshuck, td5
Last Post: magoo1
Yesterday 06:31 PM
» Replies: 74
Last Post: Dyane6
Yesterday 05:19 PM
1.6hdi starting problem
14-10-2026 01:38 PM
12-10-2026 02:50 PM
12-10-2026 02:31 PM
12-10-2026 11:22 AM
» Replies: 76
06-10-2026 12:46 PM
06-10-2026 10:00 AM
