Coolant change
Hi Guys, I want to do a coolant change but the only place it seems you can fill the system is the strange bulb on the left side which I assumed was an expansion tank. It appears to link to the radiator via an extremely small bore hose. I can't see how it would fill the system easily. Do you need some proprietary tool to force it in?
Sent from my Pixel 6a using Tapatalk
Yes you fill through the expansion tank. Be patient. Mine has a bleed next to the battery box. Just take the cap off till coolant comes out.
[-] The following 1 user says Thank You to OMG for this post:
  • jemselectrical
There are two bleeding points on the Blue HDi engine. The first one on the heater pipe where it enters the cabin through the "firewall" and the second one on the thermostat housing (on the photo).
Оpen both and fill the system through the expansion tank.
As soon as the coolant starts to flow from the bleeding points, close them and continue to fill the system.
Then start the engine, leave the expansion tank cap open. Rev the engine up to 2000-2500 RPM until the cooling fan turns on/off two times. It will take about 15-20 minutes. Check the collant level in the expansion tank and close the cap.
[-] The following 2 users say Thank You to Buki for this post:
  • cort1977, jemselectrical
(05-03-2023, 06:49 AM)Buki Wrote:  There are two bleeding points on the Blue HDi engine. The first one on the heater pipe where it enters the cabin through the "firewall" and the second one on the thermostat housing (on the photo).
Is it the same process for the 1.6 petrol I've got?
I've never seen a petrol Berlingo, they're not imported to our country...
Into Berlingos since 2003 and I have never set eyes on a B9 1.6 petrol, they are like unicorn poop. Even in 12 years on the forum, I can't remember anyone having one of these.
(05-03-2023, 01:03 PM)Zion Wrote:  Into Berlingos since 2003 and I have never set eyes on a B9 1.6 petrol, they are like unicorn poop. Even in 12 years on the forum, I can't remember anyone having one of these.
Like rocking horse shite it certainly seems so, but got one I have. It's a TU5JP NFR 16v 90ps. Apparently it's just an over bored TU3 engine as used in the M59 Berlingo's, I think they were much more common place on the MK1's
Oh we believe you. Just most folk aren't familiar and assume HDi when talking. If it's like the Tu3 then we do have a few folk who know them well. Not me, never had a petrol one.
  • jemselectrical
Hi guys,
Managed to find a comprehensive guide for dealing with servicing the coolant system and timing belt on the TU5JP NFP/NFR 1.6L petrol. Seems a pretty idiot proof tutorial, so that's reassuring
Timing belt/water pump: https://youtu.be/SroJdT60zqw
Thermostat/coolant change:
https://youtu.be/9wWBFfpa1QM
Last Post: gitt
Yesterday 08:27 PM
Not able to register
Last Post: Mike
22-01-2025 11:03 PM
2011 B9 DPF warning light
22-01-2025 10:51 PM
Last Post: Matt Haigh
22-01-2025 07:21 PM
M59 rear wheel splay...
21-01-2025 03:27 PM
Indicator/lights Stalk
Last Post: magoo1
21-01-2025 03:09 PM
Last Post: pondweed
21-01-2025 01:21 PM
21-01-2025 12:41 PM
21-01-2025 09:18 AM
» Replies: 23
Free To Collect From CO14 8LD B9/K9 Floor Mats
21-01-2025 12:43 AM
