Threads: 2
Hi guys , I have a 2019 partner ( berlingo ) I was fitting an an LED light in the rear and seem to have blown a fuse , can anyone provide a diagram or what fuse does the controls the rear light . And as a sub post , which wires to do u connect to to get the additional LED light working
Allan
Threads: 0
I’d like to have a fuse diagram too, can’t find one on line anywhere. Did you get one? Or which fuse is the rear light.
Threads: 75
Thanks Given: 223
164
Threads: 75
Thanks Given: 223
164
Oh and the BSI does not like LEDs. If you insist on fitting them, the original bulbs have to be removed so it works at all. Every lamp output is driven directly by the BSI, which is the Body Systems Interface, also it's the CAN bus bridge controller for all other systems. I'd be canny there, if you break the BSI, then you'll have a Berlingo - shaped paperweight for your driveway.
Threads: 39
Thanks Given: 1
4
26-03-2023, 12:51 PM
(This post was last modified: 26-03-2023, 12:52 PM by Romahomepete.)
Is ther a list of fuses in the handbook? there is in the previous models.
Peter
Threads: 75
Thanks Given: 223
164
26-03-2023, 04:57 PM
(This post was last modified: 26-03-2023, 04:58 PM by Sol.)
You sure Peter? I've got all versions of the B9 handbook and cannot remember seeing any fuse layouts.
Threads: 39
Thanks Given: 1
4
Am I thinking of M49 and M59s then?
I cant find my B9 book at the moment
Peter
Threads: 75
Thanks Given: 223
164
Peter I have to apologise to an extent, in the car handbook on page 188 and the van handbook page 160 there are listed fuses for all 4 fusebox options, but the diagrams accompanying them are so fuzzy as to be useless to identity any one of the fuses with certainty.
Sorry mate, you were correct in that they are in the handbook. I would struggle to use it though. Even zoomed in, the PDF versions downloaded straight from Citroen are still impossible to read the fuse numbers.
