Interior lighting
Ok , near to pulling hair out ( if I had hair) here , rear light in a 2019 van isn’t working , has anyone any idea what fuse controls this , I’ve spent hours searching net amd it ain’t listed , is it grouped with another set of equipment . Help !!!
Thank you
No idea which fuse on a K9. We have no diagrams for those. The lights are ALL controlled and powered from the BSI however, on all models and generations. So you probably blew something on the BSI.
They don't like LEDs.
The BSI is probably still mounted behind the glove box. The closest I can give you is fuse layouts for the B9 which may be close, or may be way off. F7 and F9 if they are the same. See below
Attached Files Thumbnail(s)
Thank you
15-11-2026 05:06 PM
15-11-2026 04:54 PM
One thing after another
14-11-2026 10:56 AM
14-11-2026 08:44 AM
