Powerfold wing mirror teardown
Hi guys, one of my powerfold wing mirrors had damaged outer plastics but still electrically and mechanically functions.
I've stripped it down and removed the outer plastics but it's impossible to remove the plastic shroud around the mounting base without separating the hinge section.
This looks like it must be possible as the retention sleeve that the spring bears against is keyed and does move.
I suspect it may need to be compressed to allow it to be undone. Likely no one has tried this, but if you don't ask you don't get.
Sent from my Pixel 6a using Tapatalk
I've replaced the outer shells, heated glasses and complete mirrors but never tried to dismantle the mounting part.
Today 05:49 AM
Yesterday 11:36 PM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
