Threads: 75
Thanks Given: 223
164
Passenger side inner wing, opposite the battery, there's an earth stud. (A big one).
Look above the strut top, you'll see it. May need to add a bolt there instead, to take a ring crimp.
Threads: 22
Thanks Received: 49 in 45 posts
Thanks Given: 40
4
for small consumers you can use any metal screw inside engine bay, just measure from that screw that you have continuity to the ( - ) battery terminal
If you like gaming visit
GameForest
Threads: 75
Thanks Given: 223
164
(26-03-2023, 12:33 PM)John Bilko Wrote: (19-03-2023, 06:49 AM)Zion Wrote: Passenger side inner wing, opposite the battery, there's an earth stud. (A big one).
I decided to use for my alarm system just installed. I replaced the dreaded torx with a regular M8 bolt.
Good job John.
• John Bilko
