Ambient temperature sensor
Hi
I have a 2004 peugeot partner.
On my center display, as you can see from the photo, i have no exterior temperature reading " --° ".
.jpg   20230320_000536.jpg (Size: 90.55 KB / Downloads: 11)
Does anyone know where the temperature sensor goes? And any part N°?
There are quite a few threads on the subject so a search around should throw up the info you need. The sensor is on the underside of one of the door mirrors.
(20-03-2023, 08:58 AM)cancunia Wrote:  There are quite a few threads on the subject so a search around should throw up the info you need. The sensor is on the underside of one of the door mirrors.
Hi
Thank you for your response.
I searched "Ambient temperature" and "External temperature" and the results were for B9 and K9. Not much for M59 models.
I can't even get a confirmed part N°...
Sorry, maybe I'm not looking well enough, if you have any threads, please point me in that direction.
Thank you
I thought that @saskak had done some work on this.
Here's a thread that I found...
https://www.berlingoforum.com/thread-226...ure+sensor
I'm sure the sensor connected directly to the MFD display in the M59 and to the BSI instead on the B9, so it may be possible to fit - I guess you already have one and it is not working now? Or have you never had the sensor to start with?
It was awhile ago, so memory is a bit rusty, but the temp sensor goes in the driver's mirror and connects to the door loom. The temp sensor I bought and it works on the M59 is: 6445F9. Ebay worked fine for me. One of the external temp thread is here: https://www.berlingoforum.com/thread-4053-page-2.html
[-] The following 1 user says Thank You to saskak for this post:
  • cancunia
(20-03-2023, 03:36 PM)saskak Wrote:  It was awhile ago, so memory is a bit rusty, but the temp sensor goes in the driver's mirror and connects to the door loom. The temp sensor I bought and it works on the M59 is: 6445F9. Ebay worked fine for me. One of the external temp thread is here: https://www.berlingoforum.com/thread-4053-page-2.html
Also, to make the end of the stalk button pushable to switch between stuff on the MFD: https://www.berlingoforum.com/thread-446...l#pid34076
I cannot find the thread with the photos, but here is a pdf of my ext temp install:
.pdf   outside_temp_sensor_old.pdf (Size: 1.71 MB / Downloads: 4)
Hi
Thank you for the switch idea!!! I just got the dispplay a few days ago and was dreading getting a hold of the switch! I'll make one tomorrow!
This is what the inside of my door loom looks like: i have pins at 8 and 7? Is this a good sign?
Another question, does the outside temperature affect the AC performance? Doesn't enable/disable AC from turning on (I'll explain in another thread)
Attached Files Thumbnail(s)
With the pins it should straight forward just connecting them at the mirror plug and then moving the correct pins a the pdf.
I do not have AC, but I really doubt there will be any difference to the function of AC, the computers in most of our cars are not that clever.
(21-03-2023, 08:16 AM)saskak Wrote:  With the pins it should straight forward just connecting them at the mirror plug and then moving the correct pins a the pdf.
Hi
Your help is immensely appreciated, but I'm blocked now :/ what other pins should I move? I thought since pins 8/7 were there, it means all is good.
Is there anything else to do?
An almost Hydrolock in a DV6B
Today 06:31 AM
Yesterday 06:00 PM
Cruise control retrofit
12-12-2025 05:22 PM
tyre pressure monitoring system (TPMS)
10-12-2025 07:50 AM
Wishbone Lower Control Arms Questions
09-12-2025 07:19 PM
Anti Pollution fault warning
Last Post: labeline
08-12-2025 01:00 PM
Wire through bulkhead
Last Post: Jakejjt
07-12-2025 05:25 PM
Loose tailgate spoiler
07-12-2025 04:52 PM
Engine Fan Running
04-12-2025 11:07 AM
Last Post: SonofaGun
02-12-2025 10:51 PM
