Threads: 5
The dash pod that gives all the radio info does not illuminate is it a quick fix or replacement pod ?
Threads: 69
Thanks Received: 22 in 22 posts
Thanks Given: 7
4
What vehicle have you got ,model and year etc,
nice to be important,more important to be nice
my ride is a berlingo forte 1.9d 2003 model in pukey blue
Threads: 69
Thanks Given: 7
4
as Geoff said new bulbs ,lift off pod cowling ,then you should have two screws to disconnect display and then you should have access to three white plastic lugs ?? twist and pull these out and they hold very small bulbs which you pull out and replace,if its not the bulbs ,then thats all i can help you with sorry,
Threads: 5
All fixed thanks very much for the help
