  • 9 Vote(s) - 3.67 Average
[Engine] cold starting problems
Hi I have problem with DW8 1.9 diesel .. difficult cold start first thing( 2-3 mins cranking, to get it to fire)
Once started is fine all day but left over night it has same problem next day can any one suggest what the problem could be
I changed glow plugs and checked voltage at the plugs and changed battery
many thanks
Joe
[-] The following 1 user says Thank You to Joe for this post:
  • whitebus
Try priming diesel pump under bonnet before starting mate it mite work
[-] The following 1 user says Thank You to muply for this post:
  • whitebus
Not sure how to prime the system, there dont seem to be a hand pump on show
thanks
joe
  • whitebus
(20-02-2012, 10:33 AM)Joe Wrote:  Not sure how to prime the system, there dont seem to be a hand pump on show
thanks
joe
Black rubber hand-grenade shaped thing, just keep squeezing until it goes hard...... ooooh matron
  • whitebus
thanks
joe
Lift off plastic engine cover
Look for a black plastic push button. Is next to the oval fuel filter housing lid.
Press this button until it becomes firm, then press five more times.
If you have clear fuel lines you will see any air bubbles escaping.
Otherwise could be valve clearances or lack of compression in one or more cylinders.
Let us know how you get on please..
[-] The following 1 user says Thank You to adam3rdcanvey for this post:
  • whitebus
We had this with our Berlingo last year and it needed the valve clearances adjusting unfortunately.
[-] The following 1 user says Thank You to andyps for this post:
  • whitebus
(21-02-2012, 12:22 PM)andyps Wrote:  We had this with our Berlingo last year and it needed the valve clearances adjusting unfortunately.
That would not be a 'cold start' problem per se and although poor starting would be a symptom I think that would come under the heading of 'Inadequate servicing'! Big Grin:thumbsup:
  • whitebus
I had this problem also. The fix was changing the glow plug heater box thingy. It's near the off side head light on the front frame behind the radiator. If it is this problem, it will be confirmed by no glow plug heater light displayed on dash board after inserting the ignition key. (diesel)
[-] The following 1 user says Thank You to Peter Lane for this post:
  • whitebus
Today 08:36 AM
» Replies: 15
Yesterday 05:12 PM
04-11-2026 11:37 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
