  • 20 Vote(s) - 2.8 Average
Speed sensor location, HELP!
Had the van in at least a million bits today looking for the speed sensor, no joy.
Wheel off, battery tray, air filter housing, no joy.
Found one sensor on top of the bell housing, took the plug off, rebuilt van, no joy, speedo still worked (ish)
Does any one know precisely where it is? 'above the drive shaft' is a bit vague, cos I've looked there and couldn't find it. A picture would be great.
Help.
Please.
Hi Steve,
According to Haynes manual "The vehicle speed sensor is an integral part of the speedometer drive" "The speedometer drive is on the rear of the transmission housing, next to the inner end of the right-hand drive shaft"
Hope this helps,
Griff
Landmark
Ex 1.4 Berlingo Multispace
Nope, that doesn't help one bit Sad unless the Haynes manual has a picture?
.pdf   Speedo.pdf (Size: 389.94 KB / Downloads: 177)
(20-02-2012, 01:52 PM)steve valentine Wrote:  Nope, that doesn't help one bit Sad unless the Haynes manual has a picture?
Try this
Landmark
That helps, I think I saw where that was when I had it in bits.
I'll wait for another free day to have another pop at it.
Cheers.
Hi Steve, is this any use?
Item 1620. Confusedalut:
[Image: 2vdnr80.png]
(25-02-2012, 05:46 PM)Rustscrat Wrote:  Hi Steve, is this any use?
Thanks for that! I'll have another go at this at the end of next week, armed with this pic Big Grin
A friend of mine swapped the rev cable for the speedo cable and lives happily with that solution :-) I think it was a Berlingo 02
Try this
how to download file
My 1 post in order to download an attachement...
06-10-2026 04:12 PM
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
removing front strut
16-09-2026 02:07 AM
