Threads: 26
Thanks Received: 34 in 31 posts
Thanks Given: 9
10
Sounds like a dying bearing someplace,
Best check your cambelt in case one of the pulleys, or water pump is about to destroy the engine.
230,000 miles, (Resurrected at 186,000)
Threads: 26
Thanks Given: 9
10
24-03-2023, 08:06 PM
(This post was last modified: 24-03-2023, 08:12 PM by smutts.)
But if you are lucky, ancillaries, alternator, tensioner pulley, etc.
Some diesels, eg 1.6 hdi have a freewheeling pully on the alternator, can these make noise?
A horrible grinding/ ringing noise I had years ago was a departed clutch disc shock spring that got caught in the bellhousing & was merrily lathing itself against the outside of the flywheel. A Lidl's endoscope might give you some joy.
Threads: 12
Thanks Received: 7 in 6 posts
Thanks Given: 5
Got a full service set to be safe.
This one had a free wheeling pulley, replaced with fixed one
Clutch would prolly make a constant or close to constant noise. Have a rather new clutch.
Threads: 12
Thanks Given: 5
Full service cured it. Water pump belt gear ground into housing..the only thing with physical damage. All belts, pulleys and tensioners seem fine.
