FREE - spare wheel shims for K9 Berlingo XL
I got the spare wheel pack to fit to my standard length K9 Berlingo. The pack comes with plastic shims that mount on the underside of the car to prevent the spare wheel from rattling around. There are two heights -  to fit either a 215 or 205 width tyre. I don't need the ones for the long wheelbase version. Free to a good home - useful if you already have the jack etc and don't need to buy that whole pack just to get the two bits of (admittedly useful) plastic!
Attached Files Thumbnail(s)
2022-  Citroen Berlingo Puretech Flair XTR M Eat8 1.2 automatic petrol - Soft sand, with modutop
2011-2022 - Citroen Berlingo Multispace XTR 1.6 HDi manual diesel - Iron grey, with modutop
(25-03-2023, 12:27 PM)MartinCurtis Wrote:  I got the spare wheel pack to fit to my standard length K9 Berlingo. The pack comes with plastic shims that mount on the underside of the car to prevent the spare wheel from rattling around. There are two heights -  to fit either a 215 or 205 width tyre. I don't need the ones for the long wheelbase version. Free to a good home - useful if you already have the jack etc and don't need to buy that whole pack just to get the two bits of (admittedly useful) plastic!
My spare wheel pack (from our local Vauxhall dealer) came with three different sizes of shim but no instructions as to which to fit. Which shim goes where??
Hi there. You only need one of the pairs of shims, depending on whether you have the standard or long length vehicle, and the width of spare wheel (i.e. full size or space saver). I attach the instructions I was given with my spare wheel set. Note, I have the space saver so also kept the shims required for a full size wheel in case I need to stow a damaged full size wheel under there for any period.
.pdf   Spare wheel Berlingo - ENG.pdf (Size: 346.07 KB / Downloads: 17)
Thank you very much for this. I have fitted the wrong ones but the carrier looks and feels secure. I will fit the correct ones at the next opportunity.
Cheers
Cheers
Hi are these still available, I’m using a bit of wood at the moment
2022 LWB 1.2 petrol auto combo life (AKA Berlingo K9)
Non start , turns over
Yesterday 12:20 PM
Looking for breakers with Petrol M59
Yesterday 10:29 AM
MyCitroen App
Last Post: Blakey
Yesterday 08:01 AM
Whats the S for? 19oC/19oC S
Last Post: Hughzie
26-05-2024 04:33 PM
What does a service consist of ?
Last Post: StarFish
26-05-2024 01:46 PM
Ad blue use age
Last Post: curlywurly1971
26-05-2024 08:46 AM
Air con re gas
25-05-2024 06:24 PM
Free undertray for 2011 multispace
Last Post: needsmust
25-05-2024 10:44 AM
25-05-2024 09:49 AM
99bhp & 128bhp same engine?
24-05-2024 09:42 PM
