Threads: 75
Thanks Received: 1,302 in 1,140 posts
Thanks Given: 223
163
27-03-2023, 03:37 PM
(This post was last modified: 27-03-2023, 03:39 PM by Sol.)
Looks like it pretends to be a CDC (CD changer) so it would work for audio and calls, though it states "compatible with 2005 RD4", so that's the M59 version.
Not expensive to try out though, I had a similar one on my Audi as the car stereo supported calls but not music over A2DP (figure that one out) and it was ok. Had to go to CD Changer input to hear it of course. That grey plug is Block C on the Quad-lock, and that is the CD Changer input for the Citroen stereos.
Threads: 75
Thanks Given: 223
163
27-03-2023, 08:58 PM
(This post was last modified: 27-03-2023, 09:02 PM by Sol.)
No they should all be the same, other than the VAN Vs CAN difference on the non-audio pins.
The last one you linked is also a CDC fake input (pretends to be a CD changer) and is not "aux" input. By the way, if your stereo does not have the CD Changer input available when you step through the inputs, then you would have to add that to it using Diagbox software. It may not be configured at the moment to respond to that input.
• jemselectrical
Thanks Received: 2 in 2 posts
Thanks Given: 35
I used the KTC Dab radio adapter -
https://www.kenwood-electronics.co.uk/ca...TC-500DAB/
It's a little bit clunky to wire up, but works incredibly well and gives better volume on bluetooth - aux, than it does via the aux connectors alone.
2016 PEUGEOT PARTNER TEPEE 1.6 BlueHDi 100
