Van fire help removing headliner in 2022 van
Jus had one of my dewalt batteries blow in the back of the works van two nites ago aswell as the fire damage the smoke has absorbed into the front cabins headliner is it easy to remove so i can clean it having a nightmare atm thanks
I think you'll be very lucky to find anyone who has stripped the headliner out of a 1 year old van mate, but you never know eh.
On the B9 the shelf was only held in by torx bolts at the ends and middle, and the headliner is just tucked into the rubber door seals plus a couple of fir tree clips at the back edge.
Last Post: wbchevron
Today 07:34 AM
Clocks dropping out
Last Post: Micklew
18-07-2026 09:29 PM
air con
Last Post: magoo1
18-07-2026 04:56 PM
triangle light
Last Post: Buki
18-07-2026 08:44 AM
16-07-2026 03:29 PM
Last Post: Triggermann
16-07-2026 01:47 PM
15-07-2026 12:17 PM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
