Threads: 4
Thanks Given: 2
Hi there
Just got a warning up on my 2018 1.6 (BHW). It came up with a UREA warning and then the emissions fault. Put 10 Ltrs of adblue in but it made no difference. Thought it weird as I normally get the normal countdown to refill, but nothing. Put Diagbox on which came up with the fault coder of U029D. Is this a case of replacing the NOX sensor, or is it a bit more involved than that? Any help would be very much appreciated.
Threads: 75
Thanks Given: 223
164
29-03-2023, 01:52 PM
(This post was last modified: 29-03-2023, 01:55 PM by Sol.)
Have a watch of this:
https://www.youtube.com/watch?v=ZJZd8nDygsQ
Lost comms, NOx sensor
https://www.youtube.com/watch?v=6qHce1O9oLs
Replacement of same.
If nothing else is wrong then you should get a way with a sensor or it is just disconnected underneath. Or the Adblue injector is clogged, crystalized or otherwise has s**t itself, and that is why the NOx reading is not correct.
Threads: 4
Thanks Given: 2
cheers for that Zion, replaced sensor and all warnings clear, just need to try and get the old probe out now. Tried local garages to get them to slacken off probe but not interested. Next week was nearest offer.
Threads: 75
Thanks Given: 223
164
Yeah you may need a torch flame to release it. I had a bugger of a job getting an 02 sensor out once.
Threads: 75
Thanks Given: 223
164
No mate it's fine, no coding required.
