Door wiring harness/connector
Hi all,
I recently got some door trims/cards from an M59 that look identical to my M49 ones, except they have provision for in door speakers!
So I want to put them on today, but I am expecting there to be no speaker wiring in my doors, so I want to run some cable through the connector from the body to the door. Does anyone have an idea about how they come apart, and how I can feed new wires through it?
On the B9 it's a rubber sheath that you pull back to expose a hard white plastic locking piece, with a little screwdriver you release a wee tab and the plastic bit slides out. Then you can fish wires down the tube. Fitting is reverse.
Not sure but I expect yours is the same unless it's the unscrewable large round thing. If so, others will be along to help.
Attached Files Thumbnail(s)
Had a look.. mine has a black connector that 'unscrews'. Thankfully, the door speaker wires were already installed in the doors, even though my car never had speakers in the doors.
It does now. Yay!
Cracking.
One thing after another
Yesterday 10:56 AM
Yesterday 08:44 AM
12-11-2026 10:15 AM
Last Post: Dyane6
02-11-2026 11:10 PM
