will not rev over 3k fuel pressure low ? u3fff
05-04-2023, 09:18 AM
(This post was last modified: 05-04-2023, 09:20 AM by topo259.)
hey guys !
this is my first post so go easy on me lol
im really lost with this fault i have on my van and need some advice and help in any way please,
i buy and sell vans and a really nice clean berlingo came though auctions and had to have it ,
a 2017 berlingo 1.6 hdi 75hp
starts drive and runs great no issues smoke over heating or running problems drives great ! but
will only rev to 3k no more , as if its in limp mode ?
code reader says code u3fff fuel high pressure circuit . fuel pressure lower than the reference values ?
i try and clear the code but comes straight back
ive checked the fuses and changed diesel filter
any help would be great .
Threads: 75
Thanks Received: 1,306 in 1,140 posts
Thanks Given: 223
164
I have that code if I use a generic OBD reader and mine doesn't stop at 3k, it will rev all the way.
What scanner are you using? Most non-pro diagnostic units don't work properly on a Citroen.
Threads: 9
Thanks Received: 10 in 10 posts
Thanks Given: 39
(05-04-2023, 09:18 AM)topo259 Wrote: hey guys !
Hi - I'm no mechanic but love my 2014 VTR auto diesel and read this forum for all the info it provides.
I don't think it is the speed limiter - is it? It usually goes off and has to be re-set when you switch on the ignition. But maybe you've got a different limiter?
Good luck anyway.
Threads: 75
Thanks Given: 223
164
(05-04-2023, 11:01 AM)rnamman Wrote: Hi - I'm no mechanic but love my 2014 VTR auto diesel and read this forum for all the info it provides.
Good luck anyway.
The limiter limits the road speed, not the RPM. You can still rev the nuts off it in the lower gears until you reach the limiter set speed.
I did see that there can be problems with generic code readers , What code reader is best for Citroen ?stuff ?
I don’t think it’s a speed limiter as driving back it was fine only reving to 3k speeds from 50mph upto 65mph
It revs clean just stops dead on 3k ?
Threads: 75
Thanks Given: 223
164
05-04-2023, 05:35 PM
(This post was last modified: 05-04-2023, 05:37 PM by Sol.)
(05-04-2023, 03:11 PM)topo259 Wrote: I did see that there can be problems with generic code readers , What code reader is best for Citroen ?stuff ?
Diagbox (factory software), Autel Maxi 808 Pro, Snap-On Pro, TopDon Artidiag 800 (I think that number is correct)
Basically only the Citroen official software and adaptor or the really expensive high end pro stuff. It has 5 CAN buses at different speeds, plus a LIN bus for the DPF pump, Start-Stop and the smart alternator. The BSI computer is the CAN system network bridge and controls all functions that are not engine related, and houses the anti theft system. Also carries one of up to 5 fuse boxes on it. Normally there are at least two large ones, one in the BSI behind the glovebox and the other in the engine bay beside the engine ECU.
Few cars are as complex electronically as these.
Some Info you may (will) need:
https://www.berlingoforum.com/forum-12.html
Limp mode diagnosis
https://www.berlingoforum.com/thread-20797.html
Check these pages.
Thanks very much mate all help greatly appreciated! I’ll have a read
abit of a long shot but do you think the Eolys pouch is empty ? would i have these props from that being empty ?
Threads: 75
Thanks Given: 223
164
It has no way to measure the pouch level and will only show a message when the car or van passed over 100k miles, which needs reset with Diagbox, after replacing the pouch and or the DPF too (cleaned or replaced etc) but the warning is different, and comes with a count down to no-start.
Threads: 29
Thanks Given: 67
20
Have you tried disconnecting the MAF, it gives similar symptoms to yours.
ASDA AdBlue 10 January 2026
Yesterday 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
Blower fan
04-01-2026 09:58 AM
