Which make anti roll bar drop link do people use .....
Anyone got any recommendations as to which make anti roll bar drop links are best / last longest .......
At a guess, they are all cr&p.
But treat yourself to a look at  the generous greasing that
mine had when I opened them up for a look.
B*gger all.  Angry
Got a good glop of CV grease in each now.
To open them up, you sort of gently unwind the sort of keyringy thing that holds them on.
Mind the quick's of your nails, it will hurt if you get it wrong.Exclamation
227,00 miles,  (Resurrected at 186,000)
[-] The following 1 user says Thank You to smutts for this post:
  • Blackshuck
Oh you might also need access to a decent nut splitter.
  • Blackshuck
(05-04-2023, 09:01 PM)smutts Wrote:  Oh you might also need access to a decent nut splitter.
Or angle grinder...
My van: 2008 Berlingo 1.6 HDi Enterprise - a bit ratty!
[-] The following 1 user says Thank You to RattyCortina for this post:
  • Blackshuck
Just avoid the plastic ones. Most need an Allen key to hold the joint whilst you undo the nut. Make sure your Allen key is a good fit
Peter
[-] The following 1 user says Thank You to Romahomepete for this post:
  • Blackshuck
(06-04-2023, 10:43 AM)Romahomepete Wrote:  Just avoid the plastic ones.  Most need an Allen key to hold the joint whilst you undo the nut.  Make sure your Allen key is a good fit
Peter
Torx ones are out there too, but little difference if seized.
  • Blackshuck
I always grab the angle grinder first unless I know they are recently fitted.
As to which make I just go to my local motor factors - they supply to the local trade in my area and have a reputation to keep, better than using ECP etc and taking a punt.
  • Blackshuck
Lemforder are an OEM and good quality.
2004 Peugeot Escapade 2.0HDI. 115k miles
2004 Volvo V70 2.4  208k miles
2011 Volvo XC90 215k miles
2005 Porsche Cayenne 170k miles
[-] The following 1 user says Thank You to Kyleonsite for this post:
  • Blackshuck
Or angle grinder...
Hacksaw through the thread behind the nut is normally quick enough.
I haven't bought Berlingo ones in a long time, but I normally try to get Febi Bilstein or Lemforder for suspension parts. You can normally get them from partsinmotion for as much as you can get tat from eurocarparts.
[-] The following 1 user says Thank You to ItsGreen for this post:
  • Blackshuck
Forgot to mention - Autodoc of Germany are good for parts as you can choose OEM suppliers (Lemforder, Elring, Corteco, GKN Lobro etc). Use the app and buy when the discount is 41% for max savings. Delivery is ~1 week so buy in advance
  • Blackshuck
Yesterday 09:14 PM
Yesterday 03:21 PM
Last Post: JPCoetzee
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 09:14 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
09-03-2026 05:17 PM
