Front middle seat belt bolt/spacer
Hi Guys,
Finally fitted the front middle seat belt, but was missing the lower loop bolt that fixes to the seat chassis. I've temporarily held it in place with one off the rear seat belt but I don't think it's the correct one for the job, as it seems too close to the seat chassis.
Does anyone have a blowup parts diagram, or have a pic of theirs, or could someone take a pic please.
James
Sent from my Pixel 6a using Tapatalk
That looks like the set up on mine but I have only two front seats.
Cant think why the bolts would be any different.
Try the catcar site , that will show the parts https://www.catcar.info/citroen/?lang=en
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
  • jemselectrical
the bolt is indeed different, ill try get a pic for you but may be tomorrow. Is it the one that bolts to the undertray part that detaches from the seat?
[-] The following 1 user says Thank You to rorova5 for this post:
  • jemselectrical
Thanks, it's the one circled
Sent from my ANE-LX1 using Tapatalk
(09-04-2023, 09:42 PM)jemselectrical Wrote:  Thanks, it's the one circled
Ah thought you meant the other one.
Nevertheless it does look like the correct one but I dont have rear seats so wouldn't know 100%. Heres the bolt off mine.
Attached Files Thumbnail(s)
  • jemselectrical
Legend it's the same apart from the length, which at least means it's safe to use until I get one
Proper bolt for the middle seatbelt lower fixing is 8978 JW BELT SCREW M10x150-32 James. For some reason the ServiceBox VM is not printing PDFs...
screen grab: (item 51)
  • jemselectrical
Ok NOW it works (rolls eyes)
.pdf   B9 Van Seatbelts.pdf (Size: 126.18 KB / Downloads: 10)
  • jemselectrical
(11-04-2023, 12:45 PM)Zion Wrote:  Ok NOW it works (rolls eyes)
Thank you bwana Zion How do I get access to Servicebox please bud? Is it part of Diagbox, or a separate entity all together?
Off eBay mate. ServiceBox is a separate thing and in fact should never be installed on a machine where Diagbox is already, they don't play nice.
Get the VM version from eBay and run it on VMWare Player, it works well but only officially covers up to about 2013. It's about £10, maybe less.
Certainly still good for all B9 up to 2018 as the differences are minimal.
I have it on a 64gb SD card in my laptop and run it from a VMWare Player install on the laptop itself. Point the player to the VM, answer "I moved it" and off it goes. (You'll understand when you use it the first time)
It's in a windows XP VM, I search and install cutepdf for win XP, that lets me print the stuff off. Save them to the SD card then find them in the laptop itself. You can create a shared folder in the main laptop or PC and set that up as a mapped network drive in the XP side. That lets you send stuff to and from the VM like installers for print pdf etc. Not needed but handier for me as I share the stuff on here.
I'd share my VM here but it's 11gb. Been trying to find a reliable free one for a while to post up the link but the only one I found online is Peugeot.
  • jemselectrical
Last Post: Desdinova
08-09-2026 05:46 PM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
23-08-2026 06:25 AM
