Sticky throttle
Hello guys
So I have a 2007 berlingo with a problem of a sticky throttle, when I let go of the gas to switch gears the revs stay up (or increase if I'm accelerating hard) for a second or two, it doesn't stay on forever, just for a moment but it's racking up my mileage.
Any advice on where I should look or what should I do?
I had same problem with my 08 petrol berlingo If your clutch cable isn't running smooth it does what you describe,If the clutch pedal is squeeky or stiff try looking there.
(11-04-2023, 09:40 AM)Infident Wrote:  Hello guys
This reply is a bit late but for the record,  i have had similar issue with my 2006 petrol Berlingo but only on really hot days during the summer. Plugged in Lexia and it told me it was the clutch pedal switch. Cleared faults in Lexia and the problem disappeared. i assumed it was switch wear ( 110Kmiles ) and hot conditions affecting switch actuator operation. i  got a new clutch switch but i am not flexible enough to get under the dashboard !! however problem hasn't returned for ~ 18 months so i have left it
[-] The following 1 user says Thank You to knucklerash for this post:
  • geoff
Diagbox 9.91 free download
Last Post: Slowmo
Yesterday 06:29 PM
Last Post: Slowmo
Yesterday 06:26 PM
» Replies: 29
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
Last Post: chrisl
29-01-2026 07:06 PM
28-01-2026 09:18 PM
Cheap(er) oil
28-01-2026 03:39 PM
